Ace2cool »
https://forums.nicoclub.com/ace2cool-u95120.html
Sat Jan 08, 2011 3:28 am
ALL CAPS DOESN'T REALLY HELP GET YOUR POINT ACROSS ANY BETTER THAN WHAT HAS ALREADY BEEN STATED. Try to tone it down from now on, thanks.
As far as your problem, sounds like some kind of a vacuum leak. Could be the IACV, as previously stated, or any other metal intake mating surface. On my last car, I had a "bouncing" idle, caused by loose bolts in the upper intake plenum letting air in past the MAF sensor.
A little more description than "idle problem" would also be helpful in diagnosis. The pressurization of the gas tank has absolutely no effect on the flow of fuel into the engine. That's what the fuel pump is for. Post a little bit better description of your issue and I'm sure we'll be able to help you better.
