Fuel tank lock ring... How do I get it off?
Red-KAT
Car: 1995 240sx-se ka24det
Hey all... My fuel tank lock ring on the fuel pump is on super tyte...
How did you all get youres off?
Do you know where to get the tool for this? I looked but had no luck.
Thanks.
sactos13
Car: 92 Nissan 240sx
I thought all 240's had bolts not rings....I'm getting old
For a lock ring you need a big screwdriver and a good size hammer. Find the tab off the inner lockring and knock it counter clockwise to loosen it up. At full counter clockwise you can pull it out and the assembly comes out.
Make sure you clean up the top of the tank from dust and debris otherwise that **** will all end up in the tank.
Red-KAT
Hmm... I hope i dont break one of the tabs off... That would blow.
I'm going to test my fuel pressure tonight and then install my Walbro 255 pump... (and test pressure again.. not that it should change)
I'll also mount my Aromotice FPR with new fuel line if I have time.
Thanks.
sactos13
As long as you're doing it correctly you won't. They're pretty durable and usually there's 3 or 4 on the ring you can use. I've never broken one in 15 years
Just look at it for a minute and you'll see how it works. It's not that big of a deal but at first can be a bit crazy to work with.
Anand
Car: 95 Nissan 240SX
yes,, screw driver and a hammer will get them off... just place the screw driver closest to the inner part adn you will be fine... start by tapping it lightly and hitting it harder... it will come loose..
SloS13
This man speaks the truth!
