I had that same problem with my s13 and my fuel gauge still didnt work.driftbros wrote:I have no idea what the piece of metal is but I can solve your problem for you.
By a new level sender. This is always the problem. They use cheap little resistors at the end of a float arm. Something always fails, usually the little resistor strip.
Replace it and you'll be good!!!
