as you can see, 3 of the 4 wires match up. what im wondering is if i wire in the 3 that match, will whatever the floater thing does still work? like my gas gauge, etc? the fuel pump plugs are the same. so i know ill have power there.
also will i have any problems if that plug isnt plugged up? or if i just match up the wires and use the 3 pinned plug on the chassis harness and leave the 4th wire loose?
