Fuel Tank Complete! Brake fitting dimensions needed.
Rev_D21
1991 D21 Reg 2WD Auto
1995 D21 Reg 2WD 5Spd
1996 D21 Reg 4WD 5Spd
2012 Versa 1.6S 5-Speed
Yes, I finally finished the fuel tank install on my 96 today. I ran all new hose from the fuel rail back to the tank. The engine runs like a raped ape now that it has good fuel pressure via new tank, lines and sending unit. Now here's the part that sucks and I need some information:
Ruptured the brake line that goes from the 5-way connector, next to the RH front wheel, to the load sensing valve. I am just going to bypass that line with a new one but I am not sure which fittings I will need here. Does anyone know? It's been ages I forget now.
seang
Car: Ford Fiesta ST
Scroll down in this thread and it shows the fitting used for the clutch line. IDK if it's the same or not...zer...ypass
