SeVa-S13 »
https://forums.nicoclub.com/seva-s13-u4555.html
Thu Aug 03, 2006 5:38 am
I'm at work so I can't type up a novel but;I haven't used 7MGTE injectors, so I can't say for sure there, and hearsay doesn't help. =\To run the injectors properly however, you'll need engine management of some sort to scale back the injector pulse width. (what determines how long the injector fires, controlling the amount of fuel)SAFC's, Emanage's, and chipped/hacked ECU's can all handle that, aswell as Standalones of course.
Venting your BOV will cause problems more than likely. Some piggybacks have an feature that's supposed to help keep the engine from going pig rich when venting (SAFCII's DecAir setting), but some people still have problems.I personally just run blowthrough MAFS setups if I'm venting my BOV; it eliminates that problem, aswell as any boost leaks that are before it.
For AFR's, you'll need a wideband of course, as an AFR gauge hooked up to a stock O2 sensor is just a worthless light show. People will argue over what your AFR's should be on and off boost; I try to be around 13-13.5:1 off boost, and around 12:1 on. A working knock sensor and a sharp ear are also useful tools here.
