jjisguilty »
https://forums.nicoclub.com/jjisguilty-u24141.html
Thu Feb 01, 2007 7:23 pm
I wish it was easier to explain. I was driving normally, then acceleration felt really hesitant. I would give it throttle and it would barely clime, regardless of throttle. I depressed the clutch at that point and it reved. Then i kept driving to try and make it home which was a mile away. The rpms were dropping at a slow rate while i was driving with even throttle pressure. So i tried to rev it again with the clutch depressed and it didn't rev this time. The rpms were getting lower and lower even when i downshifted. When i finally stopped in my driveway, the car stalled. I changed the fuel filter first. Then the spark plugs. Then put fuel in. Nothing helped. When i try to start it, it turns the motor but no ignition. My guesses now are fuel pressure problems or distributor/plug wire problems. Maybe even ignition. Thats about the best i can explain it.
