cyyoung2000 »
https://forums.nicoclub.com/cyyoung2000-u44191.html
Thu Jul 31, 2008 11:01 pm
Ok this may be a little long, but let me explain whats goin on and hopefully someone can help me out, thanks in advance!!!!
Alright, so the past month or so out of nowhere the ol' 91 Q is acting up.
Now this incindent only happened twice but it may help, I'll start it right up, then a few seconds later, the RPMs flutter up and down like crazy and the car dies. Then it wont start at all until a few hours later, when itll start up just fine. This started it all and it hasnt done this since.
Now, this is where the bigger problem is, I'll start the car up just fine, but at idle the rmps will be about 2 or 300 rpms higher than normal with a fairly rough idle. When i drive, there is literally NO power. i mean, no torque at all. I floor it, and the rpms will shoot up to 3500 and just flutter up and down up and down, the car does go, but slowly. I CAN cruise at about 50 but no faster than that. And after a little while, there is a burnt smell coming from the engine, smells like burnt hair. This only happens every now and then, like once a week maybe. The car does NOT always run this bad. And it only seems to happen when i drop below half a tank. Any other time, the car runs ok, but with NOTICEABLY less horsepower than when i first bought it (about 2 years ago).
So i replaced the fuel filter, had the injectors cleaned, ran some BG44k through it, and changed the oil, just to see if anything helped, which it felt like it did, but i still hav ethe problem. Now, this all feels like a fuel system problem to me. It feels as if the gas isnt being delivered or even worse, like no compression. Fuel pump seems fine, there is no buzzing or loud noises coming from it. So, i was thinking it could be a clog in the lines or something, but if that was the case wouldnt it run like crap all the time and not just occasionally?
Well let me know what you think and ask any questions you need! I really wanna figure this thing out, its killin me. Thanks guys!!!!!!
