Just like the title says I recently got the fuel system cleaned out on my 1990 pignose and now my car idles weird.
Before the cleanout my car was blowing blue smoke on startup and under heavy acceleration. Now there's no trace of blue smoke.
My car idled at 1100rpms and now it jumps between 2100 and 2600rpm as if I keep stepping on the gas but I'm not.
The shop removed my air intake, sprayed some cleaning solution in the throttle body and wiped it out. Then they hooked up a bottle of some other cleaner into my vacuum hose and stood on the gas for about 10minutes and added some STP fuel stuff to my gas. While they were doing that all this blue smoke came pouring out my exhaust and eventually turned clear so they said it was "cleaned out" but now my car idles odd like I mentioned before and they said to take it on the highway and do some "spirited driving" (95mph) to clear out the rest of the stuff that was in there and said my car would stop idling wierd.
It's now 2days later and the idle is still the same. What's going on with my car?
I dont know any better because I'm not a mechanic of any kind. Did they screw up something with my car or is this "normal"
Modified by CarShowz at 3:11 PM 9/12/2006
