the car does run, very roughly(obviously). the car never had these issues until the customer tried to turbocharge the motor, but for some odd reason it would only build 1-2psi of boost(tried diff manifolds,turbos with no luck).it had a greddy e-manage installed.Not fully though, only as a makeshift SAFC. Bigger injectors were installed. Everything was then unistalled back to stock, save for the header and hardpipe intake. it is scary sh*t!!! This is my first run in with this vehical, so all this info is from previous techs and the owner.gumby74 wrote:Does the car run at all?Is this something new or has the car/engine always had issues? Thats just scary stuff man.
thats my next conclusion as well. I came across a TSB with this same problem.ill post as i find. Thanks guys!!meangreens14 wrote:this is a wild guese, but is the fuel system maybe stuck in "prime/start" mode? that would cause more fuel to be dumped in wouldnt it? i may be way off but its just a guess.
Really?jkm_250x wrote:im no genius
jkm_250x wrote:im no genius but this is easy to know why how to fix it well sounds to me like your 1 running way way way to rich and that would be explained my the injectors if they arnt the same size so mess with your fuel and air mixture 2 you have a cyclinder missing this would solve the rough running and low boost so go threw make sure all your spark plugs are sparking this could be as simple as a bad plug wire cause if it was sparking at all some fuel would get burnt and you wouldnt have fuel running out just a wet smokey exhaust
