fuel, spark, and compression no start
MoToG
Car: rb20 240sx
so its a rebuilt sr20det black top, 150psi all the way across, tested spark very strong, checked for fuel they all spray, ecu is good. wtf please help
240trackjunkie
Car: 1990 Nissan 240sx
You have all 3 things needed for combustion. Must be wrong injector and/or spark plug firing order. That'd be my guess. Does it try to run at all?
240life
Car: 1993 Nissan 240SX S13 Coupe SR20DET blacktop
recheck your timing
Justin35ll
Car: s13 coupe sr20det
timing
MoToG
Car: rb20 240sx
i re did the timing a couple times and still nothing no pops or anything so im starting to think the gas in my tank is stale?? like im so lost right now it doesnt make any sense.
rc1honda
Car: 1992 240 sx
2007 BMW 335xi
2008 Honda CBR1000RR
Well your could try spraying some starter fluid in the intake, or maf. Might be the CAS. How did you time it? Mechanical or with a light? Check the mechanical timing. Also check your plugs and gaps.
MoToG
Car: rb20 240sx
ok so its timing and fuel. the mechanical timing is right but i guess the cas was put in wrong or is bad or somthing. i sprayed starter fluid in the throttle body and it back fired out of the throttle body so that means timing right. but i wasnt getting anything from the gas in the tank so that means the gas in the tank is bad too right
bruinbear714
Try this how to set sr20 timing guide and report back.
