fuel smell in cockpit...
SR20drftSX
Car: 240 hatch(sold) , 92 Infiniti G20 JDM Sr20
hi , yesterday i went and did a lil drifting on my favorite back road , but sometime thoruhgout the last week the county guys put fresh gravel down and they were like nickel sized stones...well anyways , wen i got back to the house and park the car i checked under the hood and it was alright..and then i started it back up and went downtown and i can smell gas very strongly in the cockpit , i mean VERY strongly...idk what the problem is...maybe i puntured a gas line of some sort..im gonna have the shop take a look at it in the AM but for now..any suggestions? and are the injected supposed to be able to rotate in the holes when i turn them?
thanks alot
Garrett , NY
SR20drftSX
me and my dad checked it out today and its one of the return lines i guess going into the front of the fram or right on the fram just beleow the passenger side of the motor..its all drippy and stuff...how much yu think that will cost to replace and how do they replace it..shouldn't be bad at all im thinking..just a simple lil line and its deff not the main line cus i get plenty of gas..thanks
Garrett
ricebike
2002 Quest
2005 Altima
deja Vu?
did this happened when u also hit a metal brake line?
is this puncture metal or rubber line?
rubber? then get "fuel injection" hose & fuel injection hose clamps (more expensive but worth it). don't get those regular fuel hose that's obviously cheap & will swell when excessive pressure is reached... no worm clamps that'll cut into the hoses...
a str8-forward common-cents fix... just don't have someone smoking a cig while working on your car if u r not doing this yourself!
SR20drftSX
haha thanks..i beleive they just used normal rubber brake line type hoses and silver hose clamp type clamps....they ran it from the front all the way back , he said it was rotted
ricebike
2002 Quest
2005 Altima
well, that aint' good... should B a metal line under thurrrrrrrrrrrrrrrrrrrrrrrrrr
not hard to get steel metal lines from the same NAPA store u got your other lines from.... a tube cutter & bender can b "rented" from autozone or a local parts slinger (usually fo free as well)....
& just buy enuff hose/clamps from the firewall area to your fuel filter.
Nick240sx
Car: 2009 Ford Fusion SE Sport
fuel filter replacements are cheap and easy. all you do it pick up the filter $6-20$ depending. and then you just loosen the clamp and vice grip the hose unless you want gas all over and then slip it out and then reinsert after you re run the new line. you might want a catch can on the floor below incase you get fuel runoff cause you most likely will.
ricebike
2002 Quest
2005 Altima
Nick, u missed his post:
previous owner ran fuel hose all the way from the filter to the tank!
not really safe...
i'd go back to OEM specs of
filter--hose--metal line--hose--tank or something like that
Nick240sx
miss his post, that i did. yes wow um i would suggest back to the oem specs.
SR20drftSX
whats the disadvantages of running just hose from the filter to the tank...it has the stock stuff from the filter to where it broke and now its rubber on the underside of the car all the way back to the tank...and whats the part number , from like walmart for the fuel filter or where should i get the filter
ricebike
2002 Quest
2005 Altima
well, as you already experienced, 1st hand risk of punctures under thurr...
plus dry-rot just because that expensive fuel injection hose is waay higher than just getting some steel lines running under the carriage... unless you're going to spend $$$$$$$$$$$ on some stainless-steel-braided-kevlar-lined-bling-bling-ching-ching-shamalamadingdong-silicone hose that won't degrade over time
filter: purlolator/wix/napa/ are decent brands... heck walmart's fram filter is ok too i guess
Modified by ricebike at 12:19 PM 6/13/2006
