boomstriker »
https://forums.nicoclub.com/boomstriker-u11720.html
Thu Jun 17, 2004 10:54 am
Some manufactures use the spring-type clamps under the hood. They are a wonderful design that provides tension on the rubber hose even years later after the rubber compresses and shrinks. They are great to use in areas that are inaccesable to re-tighten later with ease. Some guys don't like them because they're not familier with them, or maybe cause they don't have the pliers to R&R them.
Nissan uses these type of clamps on the coolant hoses, but uses stainless screw-type clamps on the HP fuel hoses. Although they are strong, secure and reliable clamps in the short haul, they don't compensate for the rubbers shrinking and compressing and will eventually seep fuel causing the smell in the cabin.
If the hose is in good shape, just tighten the clamp and the leaks will stop. If they are hard and brittle or they're already tight and leaking, they will need to be replaced.
Very often I have customer cars come in having screw type clamps replacing the original spring style on radiator, fuel, 8mm coolant, and PS return lines. Usually they are replaced with the new hose, but no matter how tight they are cranked down, within a year or two they will be leaking because the rubber compresses, but the clamp doesn't. Unless you like to re-tighten hose clamps every year and having leaks, leave the spring ones on there.
Kirk
