Fuel smell and leak in cold weather....PLEASE HELP ASAP!!!!
satdog75
Car: 1993 Maxima GXE (Vin Code H)
I recently started getting the "fuel smell in cold weather" t that most have discussed in other threads on my '93 Maxima GXE (vin code H). I have tracked it down to a fuel hose that feeds my injector rail closest to the front of the vehicle. My question is....do I have to take off the intake to replace this or is there a way to get it with the intake in place? I have attached 2 photos of the connection in question. 1 of the location of the actual leak and another of the 3 fuel lines that dissapear under the intake that feed the fuel rails. If I do have to take off the intake, do I need an entire intake gasket kit or just the upper plenum gaskets (found them at http://www2.partstrain.com/sto...65426 and not sure what all I need). At the same time I will most likely go ahead and change my valve cover gaskets since they are leaking and also tackle all the vac hoses. Any input would be awesome. Also any tips to save cash since it is a little tight after the holidays....
Heres a pic of the location of the leak.... its where the hose attaches to the front fuel rail (with the small clamp and phillips head screw). Click on image to view full size...
Heres one of the 3 lines feeding under the intake (rear side of engine)..... Click on image to view full size...
dragon285
Car: 2000 Maxima se
I had the same problem in my 5 th gen maxima. Took the fuel supply hose / pressure regulator off. didn't notice the leak until I turned the a/c on recirc. Took the assembly down to the local industrial hose place and he was able to replce the short piece of hose, crimped and everything for $3.00
