:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Fri May 06, 2005 3:23 am
...and fuel is only half of tuning.
No matter how much injector you can add, you'll still blow the motor with a stock ECU when you start pushing past the ~250rwhp barrier...WAY too much timing advance.
So if I were you (and I was once)...realize that until you're ready to spend some real cash on engine managment (AEM EMS, or JWT...or "Enthalpy" tune if it's available for you), you're limited to 250rwhp or less.
Now, with that said...a set of SR20 370cc injectors will get you to about ~250rwhp safely...and the stock MAF will max out right about there as well.
And with your base timing retarded a couple degrees, you could have a nice, safe, reliable setup...maybe ~8psi from a standard T3/T4, and just under ~250rwhp.
So even though an S-AFC can handle injectors twice as big as stock...your motor can't handle the HP that those injectors would be needed for with a stock ECU.
- Brian
