bgilly »
https://forums.nicoclub.com/bgilly-u6540.html
Sun Apr 20, 2003 11:58 am
The MCCC has fine enough of a spray so that I've never had a problem with it condensing in the intake. Plus you have to have a friend rev the motor for you while you do it to keep the motor alive (since you have to spray it in to an open vacuum line, therefore creating a large vacuum leak), so that will cause enough suction to keep it out of any nearby vacuum lines and give the motor a good cleaning. In other words, don't worry about how close you are to the throttle plate, just spray it in anywhere after the MAS and you'll be fine. Have your friend hold the RPMs at about 3000-4000 while you spray it in, because every time you spray it the motor will drop rpms real quick.
