Nobody have any input...?UhFive wrote:Couple questions...Will fuel rails from an 06 VQ35 fit an 08 VQ35? Will fuel rails for the 350z/G35 fit our VQ?
I was really wanting to know about the aftermarket ones...I find ones for the VQ, they say they are for the z/g's and I wanna know if they will work with the Alti's.el_blacky06 wrote:I haven't seen anyone switch out fuel rails from the older gen Z or G.
You can always give it a try tho. I know the qr engine parts is interchangeable from the older models to the new altimas 2.5 so it could be the same for the vq engine
Turbo is the long term goal. I got the exhaust, now I am looking into fuel rails, injectors, pump (which I heard there are none), cams and an uprev tune. After that I will Attempt to piece together a nice turbo setup.el_blacky06 wrote:From searching around websites it seems like internal parts will fit but since the engines are tuned differently from factory you won't get the same gains as you would from the 350z/g35. The fuel rails will be a plus if you're setting up to install a turbo on your coupe
