fuel rails and fpr
s13lawnornament
Car: 93' 240sx coupe
ok,so I did some searching and could not find my answer. I thought some one here might know what is the difference between the sr and ka fuel rails? I am hoping to get some stuff for my ka-t project and I want to use a synchronic fpr but the only application for nissan i have found is for a sr fuel rail and i will be running a ams fuel rail. will it bolt up? Thanks for any and all help.
lrb_2000
Car: '91 Nissan KA-T hatch
i'm pretty sure the sr20det and ka24de are about the same, they can be swapped with each other. the ka24e has a top feed rail, so it's different.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
nope i already tryed to install Sr rail on KA when i got my 370's
the feed and return line (return can be swapped for KA) are backwards and would require waste modification time to make it work ( routing of fuel line etc.). also the FPR on both KA and SR rail are the same, i matched the numbers. the rails are the same, only reason that i would have liked to mount the SR rail was, i had an hand injurie at the time and didnt feel like punching the injectors out, but i did and used vasiline to slip them into my KA rail pretty quick job and notice differnce immediately. also both rails use the same mounting flange, o-ring and bolts for stock FPR so if it work on sr rail, it will work on KA rail.
crzycav86
Car: 93 Nissan 240SX KAT
if you try to use an sr fpr, the vacuum line points into the valve cover.
