Fuel Rail
KAT S14
I am pretty sure the answer is no but does the SR20 fuel rail match up with the KA?
Tatanko
Car: 2003 Maxima SE Titanium Edition, 6-speed HLSD
You would be correct...one is side feed and the other is top feed.
IvanAtSPRacing
Car: I make cars fast
actually thats not correct. Both are side feed. The rails are identical with the exception of the mounting points.
Structure240sx
the CA fuel rail is topfeed along with the kaE
IvanAtSPRacing
Structure240sx wrote:the CA fuel rail is topfeed along with the kaE
Good call. I forget sometimes about the SOHC KA.
So to rephrase, All the SR RWD fuel rail and the KADE RWD fuel rails I have seen are the same with the exception of mounting points.
