Fuel Rail Options
DuckyD
Car: 1995 240SX
Does anyone know of a Top Feed fuel rail that uses the stock FPR type fitting on the end? I am looking for a top-feed rail but be able to still use the Nismo FPR, so looking for a rail with the stock-like end fitting.
Everything I am finding (like the Greddy/Trust) uses -AN end fittings.
Anyone?
Sil240
Car: Nissan S13 "The One Cam Wonder"
I assume you have a rb25.You might be able to make a RB26/20 rail fit.Just make sure that the Nismo FPR is the same for the 20/26 and the 25.
DuckyD
Car: 1995 240SX
Sorry, yes.. RB25.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
I'm with Brian, retrofitting a RB20 or 26 rail is the route to go for that adventure.
on a side note... Ducky! Where the heck man, haven't spoken to you in forever. You dumped the SR and went RB?
DuckyD
Car: 1995 240SX
Naw man, still knee dip in the SR.I was actually asking for someone else, because I know about 3 things about the RB25 and fuel rails isn't one of them.
virus77
Car: 95 S14, 71 240z, 97 e320
JGY sells one that keeps the stock regulator, I just installed one on a RB and blocked it off because the guy wanted an aftermarket regulator so I am sure of it lol. If you do order it make sure they give you injector o-rings specific to their rail (they were pretty beefy) and these weird clips that attach the injectors to the rail. They originally didn't send me these so just a heads up. Other than that it was a pretty nice install, haven't built any pressure in the lines yet, hopefully it doesn't leak
middle of the pagehttp://jgycustoms.com/RB20DETparts.htm
Modified by virus77 at 7:45 PM 7/23/2009
Modified by virus77 at 7:47 PM 7/23/2009
jonh317
Car: 240sx s13 sold
05 Mit Evo
http://www.freewebs.com/pallnet/products.htmTop-feed injectors, pick your rail size, and injector size 11mm or 14mm.makes one for rb20 as well.
