bentvalves »
https://forums.nicoclub.com/bentvalves-u46428.html
Thu Sep 25, 2008 12:14 pm
precisley ^ I'll share my story.
OE pintal donuts that are located on the end of the injector in the secondary intake tract are not meaty enough. Its far from a tight fit, and when the pintal end gets squeezed in, its not much better.
I had reamed my rail for Venoms, removed them and replaced with Sard, and I did just what you did, got a bunch of O-rings from other applications and used what fit best.
What I also did, was wedge an extra donut onto the pintal end, so when the rail gets tightened down, the upper donut above the injector clip, beneath the o-ring that fits into rail, became smooshed so to speak ensuring a good seal. It also expands the pintal end donut in the plenum nicely, which would otherwise likely leak.
Hope that all makes sense, its all there just read it slow.
