I have an S13 SR and im putting my Greddy intake manifold on and doing my mock up right now. I have noticed that when using the manifold with the stock rail you have to cut one of the tabs off of the fuel rail. No problem normally as the stock rail apparently comes with 4 tabs like so.
Well my New fuel rail that i have looks like this here
Already it does not have the tab on the opposing side And i still have to cut one more off of it which will make it look like this giving me only two connecting points.
It will be connecting to the intake manifold in these two spots.
I figured i would post this and see what others think, I can only hope that it will seal tight enough to not cause a vacuum leak or fuel leak. I wanted to double check with everyone here before i put my brand new injectors in the brand new rail before i realize that it wont work and have to basically break the injectors to get them out because side feed injectors are a pita to get out of the rail as we all know.
So what do you think about this? Will it cause a problem? Any other S13 SR owners out there with the same type of setup? I just need some reassurance before i put it all together.
