Fuel rail line kinked... how to fix?? *PICS*
nodr1ft
Well this is the 2nd sr20det blacktop I got, the 1st one was replaced due to two bad cylinders.
Well this blacktop is also a FML moment too because one of the fuel lines is kinked and spraying gas all over the intake manifold. Waterpump leaks like a waterfall and I have a mystery exhaust leak!
Anyways I order a ISIS screamer turbo outlet, ISIS V2 Tubular exhaust manifold, waterpump, tstat, and a oil catch can from enjuku racing. I cannot thank Ken and BG enough for their help!
Here are pics from the blacktop.. how can i fix this? get a pipe cutter and connect the fuel line? get a entire fuel line rail used?
im pointing to the kinked part of the fuel line.. yes i know my fingernails are dirty
chicos240
Car: 1995 240 SX
that looks like your line in?IDK if its THAT BIG of a deal.Your Fuel pUmp will fill the rail...your FPR will feel the pressure and open when necessary. If you are worried about it...take it to a machine shop or buy a new one...A machine shop will cost you a 100 bucks a used Fuel rail maybe 50....an aftermarkter one will be about 200...so just choose your poison.
Hijacker
Car: '92 240sx Convertible
'94 F-150
I would try to either replace it or run a soft line up to the main hard line. If it's spraying gas, it's probably not going to be easily fixed, especially given the soft nature of the metal. You'd probably do more damage than good trying to weld up the hole.
Slipstream
Car: '94 Sonoma, '90 300zx n/a
Seriously, if you're spraying fuel just replace it. Why risk it.
frftw
replace it, or maby replace the bad section of hardline with rubber a clamped on fuel hose
OM3GA
Car: A Sexy Mobile, 1993 Nissan 240sx 180sx Hatcher
Just replace it with rubber hose? I think i have that metal piece if you really want it i can find it and sell it to you?
