fuel rail leakign air ?!?!
pungkiteater_671
so i recently changed my fuel rail and while i was in the process of taking out the hardest bolt to remove fell and got lost so i was wondering if that is the cause of my engine to run like s*** ??
my engine idles fine but when i tap the gas the idle just drops and wants to die when i take my foot off it rises back up to regular idle
it also has a leak between the 4th injector and the injector spacer will that cause this problem to ???
pls help me out my car has been down for months
Modified by pungkiteater_671 at 4:34 AM 8/25/2009
OutToWinPAHC
Car: 2015 Chevy Silverado
Nissan Skyline R33 GTS-t
Nissan Skyline R32 GTR
Nissan RB20 E46 RHD
2015 Harley Vrod Muscle
1990 Nissan Patrol
You answered your own question. You have a missing mounting bolt and a leak on the rail. You haven't fixed the issue, but you have a problem. Now the cars been down a month and you don't know why? Cmon man, think about what your saying, fix the problem first, then see if it run better.
pungkiteater_671
OutToWinPAHC wrote:You answered your own question. You have a missing mounting bolt and a leak on the rail. You haven't fixed the issue, but you have a problem. Now the cars been down a month and you don't know why? Cmon man, think about what your saying, fix the problem first, then see if it run better.
alright thankyou ima see if autozone has the mounting bolt tomorrow
Modified by pungkiteater_671 at 7:17 AM 8/25/2009
2ndnissan
Car: 1990 240sx hatch
Take off the other bolt from the rail and take it with you to Lowes,Home depot,some hardware store..maybe advanced auto..whereever...matching it should NOT be hard. on whichever end the bolt was on,those two injectors aren't being pressed against the seal...of course there's a leak. If you had one of the telescoping magnetic rods you'd probably be able to get the original bolt out of the little dip it's probably still stuck in on the manifold....
Justin35ll
Car: s13 coupe sr20det
pungkiteater_671 wrote:
it also has a leak between the 4th injector and the injector spacer will that cause this problem to ???pls help me out my car has been down for months
noooo, really?
pungkiteater_671
sorry guys but i put the screw back on and my car still runs like s*** even worse..
at first it ran pretty good for a couple mins than i went to buy another screw cause the one near the rad got stripped so i bought one and replaced it now the rail has all the screws and they are all tight when i started it it ran like s*** 3rd cyl was dead so i change the injector works now than after that 4th cyl died i changed it and it worked for a lil bit and it died again checked my sparkplug and it had gas on it exhaust blows a lil smoke and smells like gas !!!
F*UCK THIS POS
