fiznat »
https://forums.nicoclub.com/fiznat-u1372.html
Sun May 08, 2005 10:36 am
ahh, welcome to one of my nightmares. I had the hardest time getting my JWT rail to seal with the injectors properly. I would tighten it down slowly, do it as evenly as possible, and fuel would still spray or dribble out of at least one injector. I found that after fiddling with it forever there WAS a tightening sequence that seemed to work, but every once in a while it would start doing it again. I ended up making new brackets for the JWT rail (the L shaped ones), and the injectors sealed up fine then... although I did eventually switch to the Phat KA-T rail anyways because I didnt trust the injectors to never leak again. (the Phat KA-T rail sealed perfectly the first time btw)
Check your o-rings though, the ones on the top that go into the rail. Even a small chip in the ring can cause huge leakages. Id reccomend just replacing all of them, a box of 8 is like 3 bucks at any local auto parts store - just bring one o-ring down for them to match. When you install them, dab some dielectric silicone grease on each ring so that they slide into the rail smoothly and dont chip or fray again.
