Joseph Cascio »
https://forums.nicoclub.com/joseph-cascio-u13229.html
Mon Mar 22, 2004 2:26 pm
Thanks for the reply. I was wondering about the entire fuel rail.I am having a problem getting it started after rebuilding the engine. I just needed to narrow down the possible issues.I have triple checked the timing chain (it's o.k.) and the distributor and wires are o.k. Tdc and all that has been double checked. I am getting only 30 to 45 lbs of compression on all four cylinders. Do you think it could be improper valve adjustment shims? After thinking about it I think I may have put the old ones on backward and on the wrong sides. Could I have damaged any valves doing this?Thanks for your help, Joe
