Fuel rail/injectors?
200sx SE-aRmed
Car: Nissan 200sx SE-R/ S13 240sx
Hey whats up, i am trying to figure out what i should do with my fuel setup before i finally install my engine. I have an aeromotive Fuel Pressure Regulator with stainless lines and fitting installed on my car, i want to know if there is any way of hooking it up to the stock SR20det fuel rail? If not what fuel rail/injectors would you guys recomend and where can i buy them cuz i cant find anything but HKS and JWT rails, but i really dont want to stop eating for a month to afford those!
Thanks in advance.
luv2spedup
Car: 89 silvia
check out ebay, i found my aluminum fuel rail for $120 shipped
compression
You can modify your stock fuel to work with stainless braided fuel lines and fancy -AN fittings (the blue/red ones).I did it to mine, wasnt very hard. Heres a picture:
Basically Cut off the ends of the fuel rail and welded in -6 AN steel fittings at each end. Then I am using an AEM fuel pressure regulator.
I can modify yours to use -6AN lines to, ...I guess I would charge $50 to do it, which includes the cost of the steel [email protected]
