Been looking for the same thing myself, having a bit of trouble locating it on their site, which one are you referring to that would work in-line with the adapter for 25$?Sil240 wrote:Go to autozone and borrow their Fuel Pressure gauge kit.Better yet order from Summit a adapter to put a little gauge on the line.It will cost you like $25 in total.
Check your Grounds!!!I was having a similar problemI thought it was my TPS but it was just a bad ground.
Cool, just the one I was looking at. The AN Fittings --- Why? I've got regular (ones it came with) fuel lines I believe, would I be alright with the fittings you've got here: (http://store.summitracing.com/partdetai ... toview=sku) ?kevwa wrote:this is what i got from summit....... http://store.summitracing.com/...w=sku http://store.summitracing.com/...w=sku i am going to switch to a fitting with AN fittings on it once i upgrade my fuel lines but for now that was cheaphttp://store.summitracing.com/...w=sku
i believe he's running the megasquirt, map based setup, so a maf isn't needed.MATTs14 wrote:How exactly do you do the blow through setup?
