huguetpj »
https://forums.nicoclub.com/huguetpj-u637.html
Wed Mar 10, 2004 9:33 am
The press is regulated by the fuel pressure regulator. Pressure drops because of two things:
1. Big injectors -> high flow -> fuel pump can't flow as much2. High fuel rail pressure -> lower fuel pump flow -> fuel pump can't flow as much
Fuel pump flow is determined by both the fuel pump rating (255lph for example) and the fuel rail pressure. The higher the pressure the less fuel the pump can flow.
So, regarding justjuiceit questions:
1. Dunno about the stock pump at 63PSI2. More fuel at higher PSI3. Nope, since the amount of fuel entering the cylinders is determined mainly by 3 things: pulse width, injector CCs and fuel rail pressure. So if u keep the pressure at 63PSI, it doesn't matter what pump you have.
And redline, I belive that if you have an inline pump u don't take out the stock pump. But I'm not positive
