Hmm, the above CC to Lph/gph numbers are for FOUR injectors correct? The ##'s would be doubled as the QX is a v8..With injector cc calculators, seems the qx56 has 240cc injectors.240cc at 51 psi = good fuel pump for ca engine?Hmph... I need to find the CC for the injectors on the QX to make a better assesment.Wonder if the fuel pumps will have a p/n that will correspond to the performance specs on the pump..81na ZX wrote:fuel requirements are due to injector size and duty cycle, obviously.
80% Duty CycleInjector - lph - gph450 - 86 - 22.8550 - 105 - 27.8660 - 126 - 33.4720 - 138 - 36.5
100% Duty Cycle (a safer estimate)Inj - lph - gph370 - 89 - 23.4450 - 108 - 28.5550 - 132 - 34.8660 - 158 - 41.8720 - 173 - 45.6
So, if your right about the QX pump pumping 26 gph, it wouldn't be safe to run it on any modded motor. It "fine" for a 100% stock motor though. No room for improvement though. And a 255lph will be safe for 720 wide open all the time. Not safe for the injectors or engine, but safe for the pump
Anytime you run a big pump, its safest to use an afpr.
That will still just give you an estimate. Voltage is directly related to flow. If you are giving it the full14v then it will be higher since the pump probably only gets about 12v due to the crappy stock wiring. But then again, I am sure its pretty easy to just hook up a 12v car battery. This post is pointless now but I made the effort to get this far so I am posting it anyway.81na ZX wrote:Thats not too hard If you have a graduated cylinder of some kind.Just run the pump on 14.4V for like 5 or 10 seconds and see how much it fills up
Uhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh,hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh,knightrider wrote:if you do use the qx fuel pump, it will flow less because the ca runs at 3 bar, which is 43psi, not 51psi, they are acheiving the flow needed for the qx by raising the fuel presure.
Well ya, but so does using a stopwatch or clock to time when to connect and disconnect the power Lots of tiny variables, but still an estimate to know if its too small.c-rad wrote:That will still just give you an estimate. Voltage is directly related to flow. If you are giving it the full14v then it will be higher since the pump probably only gets about 12v due to the crappy stock wiring. But then again, I am sure its pretty easy to just hook up a 12v car battery. This post is pointless now but I made the effort to get this far so I am posting it anyway.
Quote »i was runing 10psi daily on my ca with stock pump, with fmic, sr turbine, full3ini had no problems, i have walburo pump now though[/quote]Were these done in 240's?slownslurious wrote:the stock pump works fine on a stock swap, when my wastegate line was messed up I was running 15 psi on the stock (ka) fuel pump... I'm not saying its a good idea.How could the QX pump not be large enough when the damn thing has a giant v8 that makes way more power, and its fpr is set higher?? flow rate should increase as pressure decreases so whatever its capable of flowing on the QX, it should be capable of more on a ca18...
Thats why I said my KA pump, since that narrows it down, if only slightly (for instance, defintley not a stock suzuki pump).biosehnsucht wrote:it matters if "stock pump" in a 240 is different from "stock pump" in a suzuki
Correct As I have a front clip (if you're following my insane posts ), the CA pump is not available.. The 240 pump would cost me money (cheap bastard ), the QX pump is a "FREEEEEEEEEEBIE, ZIP, ZERO, ZILCH" (monster garage..)..biosehnsucht wrote:it matters if "stock pump" in a 240 is different from "stock pump" in a suzuki
As I said in my post, there are many variables here that could be used to make the example that you did, but for the original posters application, I think that the extremes that you are using as examples are accurate but are misleading. I'm not questioning the correctness of your statement, as it's quite true, but we're not dealing with F1 cars, and I don't think we're dealing with a poorly tuned CA either.81na ZX wrote:But its not quite that simple.
A Good NA engine has a BSFC of 0.50. It uses 0.50 lbs of fuel per hour for each horsepower it produces. A Poorly tuned FI engine has a BSFC of 0.65, and we all know stock FI computers are wicked rich. Thats about 30% more fuel per hour for a poorly tuned FI engine over a good NA engine. (0.15 is 30% of 0.50 right).
Now a well tuned FI engine can have a BSFC of about 0.60, that makes the fuel draw less.
Concievably, a 300hp CA will require as much fuel as a 430 hp NA engine.
