Fuel pump wont prime
WEAPONPLUS
Car: 95 S14 AUTO
I've searched and tried all i can think of. I have an auto 95 OBDI s14, everything stock. A while ago the car died so i tried to start it again real quick and didnt her the pump prime. I test the pump and it reads bad so i replace it. Still no start. So fast forward a bit. I've narrowed it down to the relay tripping once the key is turned on thereby cutting the power to the pump. The relay is good ive tested and swapped it. I tried hardwiring the pump with a kit from deatschwerks and the same thing happens with the relay in the kit, relay click once when i turn the key on then instantly clicks again. So my question is what would cause this? I checked all grounds and they are tight. I guess i could go back and sand them all down just to be sure. But other than that i am completely lost. Any ideas???
