Fuel pump won't stop priming.
RB280SX
I'm having an odd problem with my car. When I put the key to the "on" position, the fuel pump begins priming and won't stop. I mean, I can leave it there fore a minute and it'll keep on priming. Anyone know the cause of this?
Also, will the constitute to flooding the engine?
180fan
Car: 89 fastback
it won't flood the engine unless your injectors are open. have you checked to make sure the fpr's not stuck open?
benemorius
Car: s13, s13, eg, e36
What car/engine is it and is there any history leading up to this?
green91
Car: s13
180fan wrote:it won't flood the engine unless your injectors are open. have you checked to make sure the fpr's not stuck open?
shouldnt matter, i believe its supposed to pump for 5 seconds and then turn the pump off if the flywheel isnt turning.
RB280SX
I purchased a Walbro fuel pump. Will go over the wiring to make sure that it wasn't ghetto rigged...
Need2Boost
Hey, Im just wondering if you have figured out whats wrong yet. Im having the same problem.
i2ice4m3
Car: COUNTERSTRIKE!
I was under the impression it primes until the right pressure is built up in the system
benemorius
i2ice4m3 wrote:I was under the impression it primes until the right pressure is built up in the system
No - the ecu just has a set time for which to prime it.
