gogg wrote:I'd to like to have adjustability, for the track and weather...
The beauty of the MAF based engine management system is that you DO NOT need to adjust anything for weather.
Your MAF reads the MASS of air entering the motor...so if the air is hotter, and less dense, then less mass is read by the MAF and less fuel is injected. Very simple, and VERY effective.
And a Walbro won't typically overun your stock FPR...even though it can flow more volume and higher pressure, the extra fuel is returned to the tank...and the pressure should not increase unless you FPR is bad.
FYI...
If you're running rich, Id look at the coolant temp sensor and TPS first.
- Brian
