How do you expect the ECU for the VH45DE to function when it doesn't have the fuel pressure reserves for which it is programmed? The FPCU returns 3 different voltages depending on demand from the sensors to the ECU.tmorgan4 wrote:I will not be using the fuel pump control that Q45s are equipped with as my Pathfinder didn't come with one from the factory and I don't see a need for it.
The point is, your Pathfinder came with a VG30?E, not a VH45DE.tmorgan4 wrote:I My Pathfinder DOES NOT come with a fuel pump controller stock.
And one more...you mentioned the ECU does in fact ground the relay, which appears to be terminal 18 on the ECU.Q45tech wrote:Study diagram on ef/ec-10 in fsm.Ecu grounds relay and 2 separate wires to tell fpcu what to do: 3 steps of quasi resistance from fuel pump to ground.
Necessary to extend fp life and to match the wide range of flows from idle to max while maintaining near perfection in pressure and pulses in rail.
Don't jury rigg something that works.
Maxnix....I appreciate the response and I am not trying to come off as a idiot on this project. I have not skimped on the project one bit until now and I don't plan to. I'm simply trying to keep everything as simple as possible and avoid adding more electronics that aren't necessary and can fail. If I MUST put a Q fuel pump controller in for the pump to function properly, I will.maxnix wrote:The point is, your Pathfinder came with a VG30?E, not a VH45DE.
You need to adapt the entire air fuel system to get it to run, or engineer a new one on a dynamometer bench.
Your choice.
This is a very true statement. Which is why it makes sense to me to have 43 psi in the fuel rail at all times. The fp and fpcu can't react fast enough to have 43 at the rail by the time the computer has already set everything else in motion for WOT. If the 43psi is there at all times then everyone is waiting on the ecu to hurry up and kick up the timing and inj pulse duration.Q45tech wrote:
In a high performance engine transient response is much more difficult than steady state cruise to maintain. The oem old Q systems offered a level of fine grandularity that is only now being mainstream.
A tenth of a second lost after gear shift while things adjust badly and acceleration slows is tenth lost forever.
Maybe I mis-read your post. I am having a hard time following the voltages as well. lol Either way if you use the pathy fp relay and it calls for ground to activate it then the ecu will handle it. You could always use a manual switch as well to activate the relay, kind of "race truckish". If it uses 12v to switch then you are in the same boat but add in a relay to change the - output of the ecu to a + one or put in a "race truckish" switch.tmorgan4 wrote:
Why does the voltage at terminal 18 on the ECU go from 12V (when the fuel pump should NOT be operating) to a mere .8V when the fuel pump IS operating???
Very true. Which is why I am using the Q fp in my Z. It has a damper at the pump itself and running full speed is sending enough for wot but not enough to harm anything.Q45tech wrote:The disavantage is pumping 255 lph continuously thru the fuel rail and excessively heating the gasoline as to much moves thru engine compartment................the entire tankful will move thru engine compartment 3.35 times per hour or every 18 minutes.
