vancouverbc wrote:for my 1991 dohc the computer sends a ground signal to the fuel pump relay which in turn sends power to the pump. also, fuel pump is not always on so you obviously have to test when the pump will be on ie first 5 seconds of turning key on.Modified by vancouverbc at 9:38 PM 4/18/2009
I know you can only test in the first 5 seconds. I put the volt meter into the FP Relay hole and turned the key. Nothing.
I tested the fuel pump with external power going to the power wire so I know the fuel pump turns on. So, thanks for the help?
Anyone else?
