So, the hum I heard, that stopped, might not be a bad thing!Rex wrote:Jeff - That sounds like the "priming cycle". If you start the car and then open the trunk (while it's in park) and can hear a buzzing/whinning, then it's time to start planning the pump R&R.
I guess I'll hold it in stock, until I need it. Although, I didn't need to spend the extra $200+ right now.elwesso wrote:Maybe its pumping air out of the pump, IE slightly cavitating.....
Mine does this too..... And tis a brand new pump... Some days worse than others but its not that bad at all.....
DAEDALUS = ConfuciousDAEDALUS wrote:Just remember that a pump can be bad and still "work". Better to spend $200+ sooner than $500+ later when the pump burns out the pump controller.
I am old and not quite deaf, but I never hear the pump on either of my G50 Q45s. Haven't used a stethoscope yet, so maybe there is hope.Q45tech wrote:The FPC doesn't send any voltage to the pump. The FPC is just the electronic equivalent of a large 3 position resistor in the pump's ground circuit...........cxontrolled from the ecu.
Kind of like the HVAC fan speed controller except only 3 speeds.
Cold Start and WOT [the FPC acts almost like a short to ground], cruise [middle speed, and idle [slowest speed].
The pump's speed generates an audible tone when the wear causes the speed to decrease and come into the audible range.
Which can be a problem for young vs old folks [like me] as our hear frequency range diminishes with age and exposure.
louiegz wrote:Let me put out a stupid question out there. From what I read of the FP & the FPC on this forum, the worry about the bad fuel pump melting the sodder on the FPC is that too many amp will melt it. If you were to change the 15 amp fuse to a 10 amp fuse, would that act as a safety? Will the 10 amp fuse blow out too much to make this practical? A fuse is much cheaper that a FPC. I don't know. Would that work?
DAEDALUS wrote:EDIT: .5 ohms is nominal.
