Not with 500+whp and 35R. I am close to it's limits with the GT30R i would assume. I would say go 044 bosch and a wally or denso TT supra pump.Solow240sx wrote:Not tryin tothread jack or anything but could one of u guys tell me if a single walbro 255 will provide enough fuel to run 96lb msd injuectors??
I don't think there is a specific formula or calculation to determine the exact flow rate...but you might get 40-50% additional flow. Not as much as running two pumps in parallel.DrifterProdigy85 wrote:Ok i see. So what would the flow rate be with a Walbro Intank and a Bosch 044 Inline? It sounds like this would be plenty for my goals.
bringing it back..DrifterProdigy85 wrote:I talked to James Evans of Evans tuning and he says the Bosch 044 Inline and Walbro Intank will be enough fuel to get 700hp on e85. Next is how should i go about running the fuel lines? What size would be best? Also should the fuel pickup be made larger for more flow?
What do you run? Fuel?willteam180s13 wrote:thats what i run in my setup with braded earls lines i just got retuned on pfc 625whp 530tq
Using the 044 with the Walbro will yield higher results, than what you would expect with the 044 by itself. The 300lph that the 044 is rated at is based on the pump working alone. Using the Walbro to feed the 044, you'll be able to push more LPH. It may not be 700hp worth of flow, but it'll be much higher than the 500hp figure you've given.GTR PrYdE wrote:bringing it back..
I disagree.
A 044 flows around 300lph max, which is only ~15% more flow than a walbro, I can see it making 500whp on e85, no where near 700..
I'd believe 700whp on gas like c16
I've been searching this issue with e85 on our cars, and it seems we need dual bosch 044's or a weldon fp setup w/ surge tank for over 500whp..
This is with the ID1000cc injectors, suitable for 100 base fp.
