bigtime »
https://forums.nicoclub.com/bigtime-u373.html
Wed Sep 01, 2004 10:45 am
I thought the non starting was due to flooding, I tried the flooded proceedure, but not the case. I tried and tried to crank it till the battery died. Next day I tried boosting it, still not cranking. So I decided to just disconnect the negative battery cable to reset the ecu. After a couple of hours it cranked. I let it run for about 45 minutes, turned it off, then tried to crank it but it would not. Next morning it would not crank again. I pulled the fuel supply line, it is getting fuel. So I reset the ecu again, and it it cranked again. This is fustrating. Any suggestions?
