DanielIser »
https://forums.nicoclub.com/danieliser-u13807.html
Sun Nov 28, 2004 7:17 pm
I have had a similar problem in the past. If the car isnt getting a high enough fuel pressure due to the fuel pump being bad, then when you push the gas it will spit and sputter like its going to die but wont shut off, well maybe every now and then. But once you pass a certain rpm range without boosting, it gets smooth due to some reason I would usually try to B.S. but this time im not really sure. Maybe when its at higher RPMs there is a little more juice in the battery to supply to the pump and its pumping a little faster or something, not sure!!!
