Fuel pump?
RbKouki
Ok so its time for me to get a fuel pump, but which is the best bang for the buck?I would like to get a Denso but for close to 300 bucks I could buy 3 walbro units?
any advise on what to buy?
NISMO_RB25
Car: 1992 240SX with RB25DET, 1987 RX-7 TII
do some searching, as this has been a hot topic many many times.
I have a walbro and it works great, but I have seen people bash them for failing and some people say they are loud. I payed right around 100 for mine, and it has performed great. It does overwhelm the stock regulator, so plan on getting a FPR and a Fuel pressure gauge to set it. (I used the NISMO FPR from courtesynissan and a Fuel pressure gauge from summitracing)
JonPowell
Car: Cars, Music, My family
I love the Walbro pump, OE factory replacement size, easy to install....no complaints.
Wulfgang
.... my Walbro is quiet too.
rbsileighty
Car: 92 S13 Hatch w/ RB20 & 05 Audi S4 Avant 6MT
I'm running a MKIV Denso unit and it is awesome. I hear you can pick them up from here http://www.trademotion.com/par...gid=1 for ~$197 I got the ref off the site listed below... but double check to see if the part number is 195130-1020 just to be on the safe side (strange that a NA pump is more than the Turbo's pump).
I can hear the walbros in my friend's cars that have them... I can't hear my pump unless I got to the back of the car and put my ear by the tank access.
Here is a link to a good writeup on pump selection for VR4's:http://www.stealth316.com/2-fuelpumpguide.htm
Hope this helps!
RbKouki
So the MKIV unit fits the s14?
Modified by RbKouki at 2:53 AM 10/7/2004
rbsileighty
I had to trim the inside of the rubber isolator on the bottom of the pump to fit the MKIV unit... but yes it should fit. I can't see the DOHC S13 and S14 pumps being that different.
RbKouki
thats what I will buy thanks man..
rbsileighty
No problem... glad I could help!
Might be worth while to pick up some sort of fp gauge to keep an eye on things. That pump might outflow your regulator. I would look into a gauge and adj fpr if it's in your budget. I am running an adj. fpr, so I don't know what it's like with the stock regulator in there. I do strongly suggest that you at least get a gauge if you don't get a adj fpr.
On a side note... I noticed a huge difference in fuel pressure when I wired it directly (fused) to the battery. Make sure you put it on a ign switch/relay so that it cuts off when the car is off if you do run a direct power wire.
Let me know if you have any questions with the install. Be sure to pick up a filter if it doesn't come with one when you order it. Enjoy the pump!
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
what you do is run direct power to the pump, and use the old pump power as a relay trigger.
RbKouki
any idea where I can get a good pressure gauge, does B&M make an application that will fit the rb..
Yellow4g63
Car: 95 Nissan RB20 240SX RB20
91 Nissan NX2000 VE power
95 Nissan 240SX Stock
IvoryJ30t wrote:what you do is run direct power to the pump, and use the old pump power as a relay trigger.
Fuel pump rewire mod. Do the 240's have the same problem like the DSM's?
BoostFab
Car: S13cp, S13fb, S14z
RbKouki wrote:any idea where I can get a good pressure gauge, does B&M make an application that will fit the rb..
I used the B&M fuel gauge (summit racing has them for great price) on my RB20, go to your local PepBoys and get a 1/8 Tee (make sure the inside opening have no restriction, there are several version) and 1/8 ->5/16" barb fuel fittings and mount the gauge on there.
IvoryJ30t
no idea. i have had a handful of dsm's but no 240's.
its a shame too, because i like the 240's, but their so bandwagon right now. i hate that.
my father had one back in the early 90's i think it was a 91 that he got in 93.
he crashed it drunk driving though
BoostFab
i have a Turbo FD RX7 pump here if you want, made by Denso so is the Supra's. i think it flow close to the Turbo MK4 Supra's Pump. it will be a direct bolt on for the 240.
