:: orion :: »
https://forums.nicoclub.com/orion-u7549.html
Mon Apr 12, 2004 3:37 pm
If your stock regulator is OK, then it should be fine. I have a Walbro 255 and stock fuel rail and regulator, runs 43.5psi w/o vacuum, and not rich.
If the SR runs rich at idle, it's not due to the fuel pump.
This "walbro will make my car run rich" myth needs to die...I'm not beating up on you, but this is a common misconception that has no truth.
- Brian
