Does anyone know how low the fuel pump can clear the tank in an 85 300ZX?
The Z wouldn't start, (gas gauge is defunct), there is about 2 inches of fuel in the tank. The pump won't suck it. This seems odd to me that I would have to maintain approx 2 gallons of gas just to reach the pump.
I removed the tank for troubleshooting, thinking the pump was bad.
If I tilt the tank to the right, (towards the pump), raising the fuel level on the pump, the pump will suck the fuel and pump back into the tank via a hose.
The simple answer is just to keep it full, but that isn't a good answer. It should be able to extract all the fuel out of the tank.
Could the pump be bad or is there some other mechanical issue I'm missing, or is this normal?
Thank you for the assistance.
TQ1
