hospitalbuilder »
https://forums.nicoclub.com/hospitalbuilder-u93818.html
Sun Apr 26, 2009 6:48 am
OK, so in a long line of "My car has 180K miles, WTF Now?" I had initially had problems with my 99Q stalling out when it was cold, like within a minute or two of cranking. It always re-started and ran fine once going. That issue seems to have gone away on its own, but now, I have a starting problem. It occurs when the car has not been cranked for over 9 or 10 hours. It takes forever to crank, with the starter just turning and turning. So far it has always cranked, but I fear that one day it will not. It has happened to me twice in the morning and once after a three day stay in the airport parking lot. I have gone out and cranked it for a few seconds just before I go to bed and it cranks fine, so the 8 or 9 hour mark seems to be the limit. I have even turned the key to the on position and let it sit for ten seconds or so, thinking that this would allow the pump to pressurize the system, but that did not help. It just randomly catches eventually. Again, it runs perfectly fine once it is cranked and going.
I am thinking fuel pump, original one in the Q as far as I know. Is that a reasonable DYI. I found the pump at the store for $170. Any other thoughts on what it might be?
