fuel pump!?!?!?!
krazysob
for some reason i dont have any power going to the fuel pump. I looked at the fuse an its good. So i decided to take the pump up an connect test leads to it and it runs fine. So my question is is there any relay for the pump or could it be the wiring from the SR harness? What would be the best way to shoot the wires to see if a specific one is bad? Plus the connector looks kinda dirty so i need to clean that out an try it again. Thnx for any help
david200095367
Car: 91 fastback 93 coupe w/s14 sr20det 98 s14 kouki
yes there is a fuel pump relay.
krazysob
where is the relay? an what if that is ok? does that leave wiring?
bgsr240
Car: 90 240sx hatch sr20det redtop gt28rs-sold 89 240sx hatch S14 sr20det blacktop
I believe that the fuel pump relay is brown and located behind the drivers side kick panel, attached to the big fuse block. But dont hold me to that...
Didderson
Car: 1990 Nissan 240SX FB
'88 Nissan Hardbody pickup
'74 Datsun Z
it's in the engine bay on the passenger side fender on usdm models (240's not silvias).
It says EGI pump on the cover, that means fuel pump I dunno why.Good luck! probably just dead.
codyace
Car: S14 w/redtop
Fuel Pump Relay is up in the drivers footwell, by the fuse block on US S14's.
Check the ground on it...it's typically what fails.
krazysob
ok so what i did today i looked in FSM for my 89' an i seen on pg EF & EC 120 & 121 the trouble diagnoses for the fuel pump. The way im understanding this is to
disco the fuel pump harness and check voltage between terminal A and ground. Voltage should appear for 5 secs after switch is turned on. if not good check power supply from relay side. MINE WAS BAD
If thats not good to disco the fuel pump relay and check voltage between terminals 2,4 and ground if good check the relay for continuity (ref. EF & EC-150) MINE WAS GOOD
Check continuity between relay harness connector terminal 1 and fuel pump harness connector terminal A. MINE WAS BAD it says to repair or replace harness or connectors between terminals 1 and A
my question now is how an i suppose to do that basically the "easiest" way or "smart" way other than cutting open the whole harness and seeing if i have a short in the wire somewhere? Another thing that should be noted is that my brake lights are on at all times!? Whats left to check? the ECU? if so which pin is the fuel pump? i have the 62.
