180fan »
https://forums.nicoclub.com/180fan-u3602.html
Tue Apr 24, 2007 7:58 am
yes you should get a new fuel pump. you don't ever want to run lean with a turbo.
another possibility if you've upgraded your fuel and ecu, is that you're putting down enough power to make your clutch slip. start looking at the ratings on those clutch systems to get one that will give you all your power to your wheels. Might want to look into getting better tires and brakes as well.
