fuel pump?
A forum for owners of S30 and S130 Datsun Z's... 240Z, 260Z, 280Z and 280ZX!
prigo
Gonna have to replace the one on my '75 280Z most likely, and I'm eventually gonna be doing higher horsepower applications (v8 swap). What fuel pumps are most people using on their S30's?
prigo
Also... what wheel studs can i use that are slightly longer than the stock ones? :P
tried searching, but to no avail.
winez31
Car: 1993 s13 ka24de
walbro or inline
evildky
Car: 71 Datsun 240ZT
87 Nissan 300ZX N/A-T
06 Nissan 350Z GT
Toyota Tundra TRD RW
I'm running the MSD high pressure fuel pump, costs about $100 from summit and flowsenough fuel for like 600hp (kinda noisy but I have no interior)
as for the wheel studs, are you wanting to keep the 12x1.25 or you wanting to move to a more common thread pitch? the moroso 1/2 racing studs a popular apparenlty the fit without much work and come in a few different length's to better fit the desired application? are you wanting to use some huge thick spacers to fit high positive offset wheels? I know there are bolt on spacers available that I'd recomend ahead of the thick or stacked slipons
evildky
06 Nissan 350Z GT
and it has to be inline, the S30 and S130 used inline pumps
prigo
evildky wrote:I'm running the MSD high pressure fuel pump, costs about $100 from summit and flowsenough fuel for like 600hp (kinda noisy but I have no interior)
No, I don't want to run a huge *** spacer, but after putting on my konig rewinds in a test fit today, they look a little snug to the struts. I was gonna run like a 5MM or so just to ensure no tire rub.
And I have no prob sticking to 12 x 1.25, they're the same as my subaru :P
Ya know... now that I think about it... the studs that my subaru uses may fit....
I will test it monday! They're about the length I want. Muahahahaha.
And that MSD is an inline pump? Just plugs right in where the stock one was?
evildky
06 Nissan 350Z GT
yup, both pumps use ring terminals, the only problem is that the MSD uses and 1/2" inlet and when I was running rubber hose up to the pump it would suck itself shut where I had the hose bent a bit, I have since replaced ti with a section of aluminum tubing with no problems
Return to “Datsun Z Forum”
