my mom's van burned to the ground for that reason. she was having some electricla problems, and the chrystler techs decided to put a bigger fuse in to solve the problem. about a month later the dash caught fire and that was all she wrote...Chezedik wrote:I don't know, I never blew mine. Then I hardwired it later. You shouldn't use a larger fuse to solve your problem, because the wire they used was only rated at so much amps. You can probably get away with it, but don't think it is the right way to do things. Also, if you hardwire it, you will get constant flow because the voltage will remain constant. So if you turbo, you will be safer.
