DAEDALUS »
https://forums.nicoclub.com/daedalus-u128.html
Tue Jan 21, 2003 4:25 pm
No special tools required for this one, and you can expect to pay at least a few hundred bucks at a dealer in labor alone. It's easy enough to tackle on your own. The most important thing is to remember you're opening a gas system, so take extra precautions. Wear a ground strap if you have any ESD problems. Next most important thing is to release the pressure of the system first. Pull the fuel pump fuse and run the car till it dies. Then crank it a few more times.
http://www.nissaninfiniticlub....=6268
When you get to the flare nuts on the gas tank, loosen them slowly. If fuel starts to leak out of the first one you loosen, then close it back up gently and loosen the other one. One is a vent, the other's a liquid line. You want to vent first. Have a lot of shop towels around to catch any spills and minimze clean-up time.
