fuel pump sock???
turbonola
Car: 91 240sx coupe
would a clogged pump sock cause sputtering? i've changed my pump sock more than once since my second attempt at turboing. the reason i have to keep changing it is because the first time i turbo'd hte car i stupidly sealed my fuel pump access port (s13) with water pump gasketmaker. the gasoline quickly ate right through it. i thought i got all the gasket maker out but i guess not. the car sputters like it's a boost leak so i tested it and found a leak. i fixed the leak the same day and the car still sputtrers. it's driveable but i'd like to be able to push the car hard when i autocross it.
LeroyBrown
Car: 1995 nissan 240sx s14 blacktop
Im not to sure, but i have the original pump sock on my 255 walboro on my blacktop SR20and that sock has at least 175,000
480sx
Car: 1996 Pearl White 240sx
Yes, a clogged fuel pump sock could potentially cause studdering. It could also destroy your pump. Just make sure you dont have another boost leak first. It would also be very helpful to have a fuel pressure gauge. That would tell you for sure if its a fuel problem. You can install the gauge then have a smog shop take your car on a dyno and simulate the driving conditions where you get the studdering.
turbonola
Car: 91 240sx coupe
do you know if hatch and coupe fuel tanks are the same?
turbonola
Car: 91 240sx coupe
damn it, i found a leak by using a smoke tester. i plug the machine into the intake and push smoke throught the entire system until i see smoke. the culprit was my egay bov. lol, i know i guess i'll be in the market for a name brand bov.
WDRacing
Smoke test...awsome idea. Post pics of said tester or I will ban you...and log in with your name and make all kinds of threads declaring your gheyness
esahuque
Car: 95 240sx KA-T, 04 frontier
WDRacing wrote:Smoke test...awsome idea. Post pics of said tester or I will ban you...and log in with your name and make all kinds of threads declaring your gheyness
to late for that we already know about his gheyness
turbonola
Car: 91 240sx coupe
hey eric you should post the pic of me in those thigh highs lol.
turbonola
Car: 91 240sx coupe
turbonola wrote:do you know if hatch and coupe fuel tanks are the same?
anyone?
480sx
Pretty sure they are the same.
Im pickin up one of those leak testers.. 350ish used FTW. So many uses for one of those.
esahuque
turbonola wrote:hey eric you should post the pic of me in those thigh highs lol.
let me find the pic
turbonola
Car: 91 240sx coupe
esahuque wrote:let me find the pic
uh how bout no. lol
turbonola
Car: 91 240sx coupe
ok i've come to the conclusion that it's not a fuel issue causing the sputtering. as much as i'd like it to be that simple it isn't. i think it's something else, maybe electrical. the reason i say that is because the car cuts out like it wants to die. it only happens when i go wot but it only does it if the car has been idling for long periods of time. when i first start the car and let it warm up i can drive it at half throttle maybe 3/4 throttle but it'll still sputter. it cant just be a clogged fuel sock because i've driven the car hard before with a clogged sock. this problem just started happening after i fixed a few boost leaks. throw out any scenarios you can think of cuz i'm all tapped out.
turbonola
Car: 91 240sx coupe
ok here i go talking to myself again but i think you should just change the sock this weekend for the autox and if it works you know you have to change your tank or clean it.
turbonola
Car: 91 240sx coupe
oh and recirculate your bov, i don't think that jgs attachment is workin
turbonola
Car: 91 240sx coupe
so............... again i may be an idiot. i haven't tested it yet but my timing might have been way off. as in way retarded, like 9* retarded . like i was running 9* at idle instead of 20*. so now i have it set at 20*, wish me luck.
turbonola
Car: 91 240sx coupe
i was able to check this at my friends shop with his diagnostic tool "verus".
http://www.tomorrowstechnician....aspx
turbonola
Car: 91 240sx coupe
so it was the pump sock wasn't it.
yeah.
so you're gonna change the tank now right?
you know it. the car ran so awsome today i was fudgin stoked. to feel the power again was great so i have no choice but to fix it.
i heard that the pump sock was brown.
yeah dude shyte was nasty. looked like someone took a handful of dirt and shoved it in my tank. i just gotta find time to to pull the tank outta my hatch and put it in my coupe.
well do the damn thing.
esahuque
sweet video evidence of his car running good.
http://vids.myspace.com/index....15283
SullivanRacing06
Car: r32 gtst, 06 350z, r32 gtr, rs4 steaga, 04 350z, f350/6bt
damm do u have a upgraded fuel pump yet? if ur going to be pulling it back apart better off just replacign the pump n the sock with the 255 unit n sock
turbonola
Car: 91 240sx coupe
SullivanRacing06 wrote:damm do u have a upgraded fuel pump yet? if ur going to be pulling it back apart better off just replacign the pump n the sock with the 255 unit n sock
are you serious? who in there right mind runs 16psi on a stock fuel pump. better yet, who turbo's there 240sx without an upgraded pump. oh and yes i do have a walbro sir.
