tom91z »
https://forums.nicoclub.com/tom91z-u182319.html
Wed Apr 20, 2011 7:21 am
OK, I figured out the other line. There are two tab looking things on either side of the connection. It looks like they are meant to be pushed in but they are not. You actually need to use a small screwdriver to gently pry them out from the top of the tab. Once you get the tabs pulled out of the line you can pull the line off the sending unit. This might have to be done but in my case I couldn't get my arm in the tank and move around like I need to.
Once I could see into the tank there is a large casing the pump sits in and the case will lift free of the tank. There is a clamp towards the passenger side that holds the case in its place, you can pry up from that point with your bare hand and the case will pop out of it. This might not need to be done either but I couldn't see how the pump was help in place.
As far as getting the pump out of the case, well, I still haven't gotten that far. I played with it for a minute but couldn't get it. It looks like it pulls right out as I didn't see anything holding it in. I'll update as I go. Thanks.
